New firmware version 1.14 July 02, 2016 12:48PM |
Re: New firmware version 1.14 July 03, 2016 07:19AM |
Re: New firmware version 1.14 July 04, 2016 03:12AM |
Re: New firmware version 1.14 July 04, 2016 07:03AM |
DADIY
Hoping the Duet 0.8 is a typo and you not dropping support for us old 0.6 owners.
Re: New firmware version 1.14 July 04, 2016 08:18AM |
SleepyPrince
Hi David, I am having problem with 1.14 on my Duet 0.8.5 delta, once I hit home all
The carriages move to the top and reach the endstops twice as expected
but then the motor will make a high pitch noise like it's stuck or something and the Duet will disconnect
need to do a power cycle to reconnect to it.
I tried running the homedelta.g 1 line at a time
It's the line: G1 Z-5 F2000 ; down a few mm so that we can centre the head
that causes the problem.
When I revert to 1.13b the problem is gone.
I have attached my config.g and homedelta.g, I don't have any M569 remap or M584 in it so I am not sure what went wrong.
Re: New firmware version 1.14 July 04, 2016 08:25AM |
Re: New firmware version 1.14 July 04, 2016 04:14PM |
Re: New firmware version 1.14 July 06, 2016 06:06PM |
Re: New firmware version 1.14 July 07, 2016 04:22AM |
SleepyPrince
Hi David, just to let you know my homing problem has been resolved.
But I didn't spend too much time figuring out what the actual problem was.
I re-downloaded the firmware, up the motor current and set the speed lower all at the same time.
only thing I know is that the speed wasn't the problem since I set it back up to 2000 there wasn't any jam.
Re: New firmware version 1.14 July 09, 2016 08:45AM |
Re: New firmware version 1.14 July 09, 2016 09:09AM |
Re: New firmware version 1.14 August 08, 2016 02:36PM |
Re: New firmware version 1.14 August 08, 2016 02:40PM |
Re: New firmware version 1.14 August 08, 2016 04:12PM |
percar
Is there a Gcode and Mcode command list for the latest firmware around someplace
