Re: New firmware 1.15 release candidate 3 September 05, 2016 02:03PM |
Re: New firmware 1.15 release candidate 3 September 05, 2016 03:40PM |
joestefano
dc42
CRPerryJr
Thank you dc42 for your reply.
Do you have an idea why I am experiencing item #1 since upgrading to Duet FW 1.15b and Paneldue 1.14? Nothing has changed hardware-wise since first installation of Duet FW 1.11 and Paneldue 1.13 back in May. This only occurs at power on. Reboots do not reproduce the issue.
I can only think that it is something to do with the extra 0.5 second startup delay in 1.15b. However, I don't understand why you don't get a successful connection. The initial request from PanelDue may be coming too soon for the Duet to response to it, but it should respond to the retries. Please can you try 1.15b again, with a PC connected via USB running Pronterface or another host, and send M111 S1 P3 to enable gcode debugging. Then see if you get any "aux:" gcode messages echoed.
PS - also, when PanelDue is displaying "Starting up", do the temperatures and other parameters look sensible, and can you still switch to other pages using the buttons at the bottom?
Same problem here with my 7" screen but not my 4.3". when it is locked on "Starting Up" none of the buttons work and the parameters are at 0. I will try and connect via USB and get more info.
Re: New firmware 1.15 release candidate 3 September 05, 2016 04:14PM |
Masterjuggler
I noticed that after uploading too many gcode files, the printer would disconnect from DWC when trying to view the list of uploaded files. Upload & print worked fine, I just couldn't view the list of previously uploaded files.
I am unsure if this is a function of sheer number of files or size of the gcode folder on the sd card, but after moving the card to my computer to manually delete files, I now have no issue through DWC. It's on firmware 1.15b and DWC 1.12.
I've got a backlog of stuff to print at the moment, but if I get some downtime I'll experiment to see if I can reproduce the issue.
Re: New firmware 1.15 release candidate 3 September 09, 2016 08:28AM |
minimum
Creep is fixed.
I tried to use the new autotuning feature:
For test temp, I set 200C. Heats up nice and very smoothly until temp more or less stabilises at about 197.5-198C. After a short period I get message "Error: heating fault on heater 1, temperature rising much more slowly than the expected 0.0°C/sec" and heater faults.
I'm sure most of the problem is coming from my abnormally powerful heater (12V heater @ 15,1V).
For now I have played around almost an hour with heater, trying to reproduce the fault. So far unsuccessful.
Edit: Thank you David!
Re: New firmware 1.15 release candidate 3 September 09, 2016 08:32AM |
gen2eng
I'm seeing what I believe is a glitch with the new temperature monitoring code.
My typical print startup routine is:
Preheat the bed
Preheat the hotend to 170C
Auto Calibrate the bed
Bring the hotend to printer temperature and print.
I goofed and managed to knock the bed off my FSR sensors before the normal routine and killed power immediately when I saw the auto calibrate failing.
After powering back up, the PanelDue was showing temperatures in a purple/dark red color and I could not set the temperatures manually, nor would it respond to gcode for temperature changes until the bed and the hotend had cooled down closer to ambient temperatures.
I suspect it sees what it believes is an elevated temperature at startup and throws an error? Can it monitor for a few seconds and look for a drop and clear the error at startup?
I've got a lot of thermal mass in my heated bed, so it takes about 30 minutes to get back down to ambient temps to restart the print job. AND, I will be more careful next time, but it's a behavior that may confuse others.
Thanks!
Re: New firmware 1.15 release candidate 3 September 10, 2016 08:23AM |
Re: New firmware 1.15 release candidate 3 September 19, 2016 07:56AM |
gen2eng
Updated to 1.15c and I'm still getting the purple temp and unable to change. I'm still using 1.14 PanelDue firmware with a 0.8.5 board.
Re: New firmware 1.15 release candidate 3 September 22, 2016 05:32PM |
Re: New firmware 1.15 release candidate 3 September 23, 2016 02:46AM |
Re: New firmware 1.15 release candidate 3 September 23, 2016 07:06AM |
dc42
The firmware honours the acceleration and jerk settings you configure in config.g. If you feel that there is too much stress on the printer at direction changes, try reducing the acceleration and/or jerk settings.
Ideally we would only need an acceleration setting and no jerk would be allowed. Unfortunately, circles and curves in gcode generated from STL files are made up of sequences of short straight line segments. If no jerk was allowed, then the print head would have to come to a standstill between each pair of line segments because of the direction change, and printing curves would be very slow. So the jerk setting needs to be high enough so that curves are printed at a reasonable speed.
Regarding pausing while printing large curves, this was a known problem in older firmware when printing at high speeds. I was able to print my test curves smoothly at 100mm/sec but not at 200mm/sec. This is fixed in 1.15.
You may stil get pausing if you print from a PC over USB instead of from SD card, especially if your PC software is not configured to use driver-level flow control.
HTH David
Re: New firmware 1.15 release candidate 3 September 23, 2016 07:11AM |
