Web Control iPhone/iPad interaction issues
Posted by zeplin
August 31, 2016 04:27PM
I have not successfully connected to my Duet though a mobile device. I have tried both an iPad Pro and iPhone 6S and get the same result. I can load the web interface and get all the icons but it will not connect. Initial, I thought that it was the password that was not resolving properly though the interface so I commented it out. No change, it did not allow connection. So I thought it might be the dark theme so I went to the stock theme without a password. Still no connection and this is with a the knowledge that I just had connection with my computer to the Duet.
So, I researched if there was some switch or command that I was missing to enable the connection. But, to date I have not found anything save a small blearb saying that the code was borrowed/written for mobile devices. But, i can not remember where I found that to bring in as a reference.
Both iPad and iPhone have the 'connect' icons that are interact-able but i do not get any results.
What am i doing wrong? Does anyone do this to confirm that I am doing something wrong.
Please, Help. Note: I have only had my Duet for a month or two at the most.
Re: Web Control iPhone/iPad interaction issues
August 31, 2016 04:31PM
DWC uses AJAX and there are issues with AJAX not working with Safari on iOS.
I was told in this thread that it does work with Chrome on iOS, but I didn't bother trying.
Edited 4 time(s). Last edit at 08/31/2016 04:34PM by PDBeal.
August 31, 2016 05:37PM
Well, that is not cool for iOS being stupid and not supporting AJAX
September 01, 2016 11:13AM
Of course Safari supports AJAX. Otherwise, all kinds of sites would break.
DWC works fine for me on both my iPhone and iPad. Are you using a very old version of iOS?
September 01, 2016 11:17AM
I used to have issues loading DWC on my Duet 0.8.5. The web server seemingly randomly gave a 404 reply for some (different ones each time) resources. So that's some kind of bug on the server-side.
September 01, 2016 05:14PM
Not to old maybe one version back. so that leads me to belive that i am doing something wrong I did not think that Java in general worked on iOS. Which i though AJAX was Java will have to look into it now.
September 01, 2016 05:28PM
The J in Ajax is JavaScript, not Java.
September 01, 2016 05:33PM
On my iPad the only weird stuff I saw was with editing files. All the other operations work fine.
So for configuration work I fire up and use my laptop but for starting and monitoring prints the iPad works great.
Edited 1 time(s). Last edit at 09/01/2016 05:33PM by WZ9V.
September 04, 2016 02:15AM
I get the same behaviour with midori and chrome browsers on a rapberry pi 3
