Possible bug in elasticity compensation when extremely low values are used September 03, 2016 05:34PM |
Re: Possible bug in elasticity compensation when extremely low values are used September 03, 2016 05:38PM |
Re: Possible bug in elasticity compensation when extremely low values are used September 03, 2016 06:08PM |
Re: Possible bug in elasticity compensation when extremely low values are used September 04, 2016 12:31AM |
Re: Possible bug in elasticity compensation when extremely low values are used September 04, 2016 10:47AM |
Re: Possible bug in elasticity compensation when extremely low values are used September 04, 2016 01:30PM |
Re: Possible bug in elasticity compensation when extremely low values are used September 05, 2016 04:31PM |
dc42
It's built in to RRF. See [reprap.org]. It helps wherever extrusion speed varies over a move, including corners.
Re: Possible bug in elasticity compensation when extremely low values are used September 05, 2016 05:34PM |
Re: Possible bug in elasticity compensation when extremely low values are used September 06, 2016 02:23AM |
Re: Possible bug in elasticity compensation when extremely low values are used September 06, 2016 07:42AM |
unromeo21
Oh, sorry, that was a typo. The value was S0.15. The results were excellent, infill was uniform and no gaps.
Re: Possible bug in elasticity compensation when extremely low values are used September 06, 2016 10:14AM |
Re: Possible bug in elasticity compensation when extremely low values are used September 06, 2016 05:40PM |
Re: Possible bug in elasticity compensation when extremely low values are used September 07, 2016 06:31AM |
Re: Possible bug in elasticity compensation when extremely low values are used September 07, 2016 09:39AM |
Re: Possible bug in elasticity compensation when extremely low values are used September 14, 2016 08:33PM |
Re: Possible bug in elasticity compensation when extremely low values are used September 15, 2016 04:35AM |
Re: Possible bug in elasticity compensation when extremely low values are used September 15, 2016 12:38PM |
unromeo21
Did some more tests, I can confirm that skipped steps only happen when the M572 is used. I have now moved to direct extrusion and given up on bowden tube, so I don't think I am going to need this feature at this moment, but the second extruder might be installed with bowden, so... would be nice if the bug gets fixed.
Thanks
Re: Possible bug in elasticity compensation when extremely low values are used October 01, 2016 07:33AM |
Re: Possible bug in elasticity compensation when extremely low values are used October 01, 2016 07:37PM |
Re: Possible bug in elasticity compensation when extremely low values are used October 03, 2016 10:39AM |
G1 X12.355 Y16.707 E0.0046 G10 G1 X10.435 Y16.598 F7800 G1 X10.435 Y14.836 F7800 G1 X7.565 Y14.836 F7800 G1 X7.565 Y16.435 F7800 G1 X0.793 Y16.050 F7800 G11 G1 X1.264 Y15.579 E0.0199 F3600 G1 X1.264 Y14.900 E0.0203
M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2) M203 X20000 Y20000 Z20000 E7200 ; Maximum speeds (mm/min) M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
=== Move === MaxReps: 5, StepErrors: 0, MaxWait: 2ms, Underruns: 0, 0
Firmware Name: RepRapFirmware for Duet WiFi Firmware Version: 1.15e (2016-10-02) WiFi Server Version: 1.02 Web Interface Version: 1.12
Re: Possible bug in elasticity compensation when extremely low values are used October 03, 2016 10:56AM |
Re: Possible bug in elasticity compensation when extremely low values are used October 07, 2016 04:22PM |
Re: Possible bug in elasticity compensation when extremely low values are used October 16, 2016 01:27PM |
