Re: M42 Pins September 04, 2016 06:26PM |
Admin Registered: 16 years ago Posts: 13,888 |
Re: M42 Pins September 04, 2016 06:29PM |
Re: M42 Pins September 04, 2016 06:59PM |
Re: M42 Pins September 04, 2016 07:23PM |
Re: M42 Pins September 04, 2016 07:55PM |
Re: M42 Pins September 04, 2016 08:14PM |
PRZ
Pinout of the expansion connector is defined here : [reprap.org]
Note that pin names refer to the Arduino Due pin naming, which may sometimes help.
[edit] here Arduino Due pins schematic. The ref are the gray one : [www.robgray.com]
Duet do have pins which don't exists on Arduino Due, hence the 'X' pins.
Note there are a few differences between Duet 0.6 and Duet 0.8.5. Duet WiFi is another story.
Re: M42 Pins September 04, 2016 09:14PM |
Re: M42 Pins September 04, 2016 09:15PM |
PRZ
On schematic, PB16 D67 is pin 32, not 34.
What I think (I am not involved in the firmware, but I already tracked pins with difficulties to get them) is that internally in the firmware, the pins have the same numbers as the arduino digital pins, probably because they started to write firmware with Arduino Library. And this was probably also difficult for programmer, as this is Dan Newman which started the pinout page (he ported the RRF firmware on RADDS).
I've tried to make the Pinout page easier to find because it was really a relief when I discover this page, but it seems that this was not so successful.
Re: M42 Pins September 05, 2016 04:48AM |
ElmoC
VDX
... the Pins A0 to A11 are "digitally" numbered as 54 to 65
A0 = 54
A1 = 55
A10 = 64
A11 = 65
That still doesn't answer where on the board they are located so I can connect to them. Say I wanted to control '66 AD13'. Where on the board would I connect to?
Re: M42 Pins September 05, 2016 04:17PM |
Re: M42 Pins September 05, 2016 04:40PM |
Re: M42 Pins September 05, 2016 05:46PM |
Re: M42 Pins September 05, 2016 06:16PM |
Re: M42 Pins September 05, 2016 09:07PM |
Re: M42 Pins September 05, 2016 10:43PM |
