I am using DUET-0.6 boards for my cartesian type printers. I am planning to build a H-bot style printer. I have seen that SD-image is supported for CoreXY.
Does DUET board support H-bot gantry? If yes, which profile should I use?
My understanding is that H-bot and CoreXY have the same movement kinematics, so the CoreXY configuration should work. Perhaps someone else can confirm this.
Quote dc42
Correct. Running my h bot on a duet. Use the corexy files for the SD card.
