RepRapFirmware minor release 1.15e October 02, 2016 06:23AM |
Re: RepRapFirmware minor release 1.15e October 02, 2016 09:59AM |
Re: RepRapFirmware minor release 1.15e October 02, 2016 10:59AM |
;Timeout for Heater Errors ;Pnnn Time in seconds for which a temperature anomaly ;Tnnn Permitted temperature excursion from the setpoint M570 H0 P15 T25 M570 H1 P15 T25
Re: RepRapFirmware minor release 1.15e October 02, 2016 02:35PM |
Re: RepRapFirmware minor release 1.15e October 02, 2016 03:37PM |
Re: RepRapFirmware minor release 1.15e October 02, 2016 05:49PM |
Re: RepRapFirmware minor release 1.15e October 03, 2016 04:00AM |
Re: RepRapFirmware minor release 1.15e October 03, 2016 10:42AM |
Re: RepRapFirmware minor release 1.15e October 03, 2016 12:59PM |
Re: RepRapFirmware minor release 1.15e October 10, 2016 03:48AM |
If a heater fault occurs then any SD card print in progress is abandoned. Currently sys/cancel.g is not run, so the head just stops wherever it is.
Re: RepRapFirmware minor release 1.15e October 10, 2016 04:56AM |
Re: RepRapFirmware minor release 1.15e October 10, 2016 02:45PM |
19:40:53M122 === Diagnostics === Used output buffers: 4 of 32 (28 max) === Platform === Memory usage: Program static ram used: 45328 Dynamic ram used: 41776 Recycled dynamic ram: 3008 Current stack ram used: 2760 Maximum stack ram used: 5956 Never used ram: 2236 Last reset 02:59:38 ago, cause: power up Last software reset code & available RAM: 0x0003, 2896 Spinning module during software reset: GCodes Error status: 0 Bed probe heights: -0.561 -0.573 -0.435 -0.560 -0.504 -0.522 -0.471 -0.522 -0.494 -0.510 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 Free file entries: 10 SD card 0 detected, interface speed: 21.0MBytes/sec SD card longest block write time: 374.3ms MCU temperature: min 7.1, current 53.6, max 57.9 Slowest main loop (seconds): 0.375732; fastest: 0.000000 === Move === MaxReps: 6, StepErrors: 0, MaxWait: 2ms, Underruns: 0, 0 === Heat === Bed heater = 0, chamber heater = -1 Heater 0 is on, I-accum = 0.1 === GCodes === Move available? no Stack pointer: 0 of 5 macro is idle http is ready with "M122" telnet is idle serial is idle aux is idle file is idle === Network === Free connections: 15 of 16 Free transactions: 23 of 24 === Webserver === HTTP sessions: 1 of 8 FTP connections: 0, state 0 Telnet connections: 0, state 0
Re: RepRapFirmware minor release 1.15e October 10, 2016 04:41PM |
Re: RepRapFirmware minor release 1.15e October 12, 2016 04:45AM |
Re: RepRapFirmware minor release 1.15e November 10, 2016 02:11PM |
dc42
- Max temperature excursion and heater fault trigger time are now configurable via M570. See [reprap.org].
Re: RepRapFirmware minor release 1.15e November 10, 2016 05:02PM |
Re: RepRapFirmware minor release 1.15e November 11, 2016 11:18AM |
