building reprapfirmware can't find the binary file?? October 29, 2016 11:47PM |
Re: building reprapfirmware can't find the binary file?? October 30, 2016 08:27AM |
Re: building reprapfirmware can't find the binary file?? October 30, 2016 09:03AM |
Re: building reprapfirmware can't find the binary file?? October 30, 2016 09:44AM |
Re: building reprapfirmware can't find the binary file?? October 30, 2016 09:35PM |
dc42
In Eclipse you need to select the build configuration for both projects according to which Duet you are building firmware for. If you select SAM3X8E (for the Duet 0.6 or 0.8.5) then the RepRapFirmware.bin file is created in the SAM3X8E subfolder of the RepRapFirmware folder in the Eclipse workspace. Similarly the SAM4E8E configuration for the Duet WiFi is build in the RepRapFirmware/SAM4E8£ folder.
HTH David
Re: building reprapfirmware can't find the binary file?? October 31, 2016 05:26PM |
Re: building reprapfirmware can't find the binary file?? November 01, 2016 02:22AM |
Re: building reprapfirmware can't find the binary file?? November 01, 2016 02:36AM |
Re: building reprapfirmware can't find the binary file?? November 02, 2016 11:45AM |
it says:Quote
dc42
Try doing a rebuild or a clean and build, then post the end of the console window output.
Re: building reprapfirmware can't find the binary file?? November 02, 2016 11:55AM |
Re: building reprapfirmware can't find the binary file?? November 03, 2016 01:45PM |
Re: building reprapfirmware can't find the binary file?? November 04, 2016 07:10AM |
Re: building reprapfirmware can't find the binary file?? November 20, 2016 11:29PM |
Re: building reprapfirmware can't find the binary file?? November 21, 2016 02:45AM |
Re: building reprapfirmware can't find the binary file?? November 21, 2016 09:45PM |
