DWC File Upload.
Posted by DADIY
DWC File Upload.
November 22, 2016 12:05PM
I see on the settings tab the file upload description has changed to "Here you can upload firmware, Duet WiFi and Duet Web Control files as well".
So can I upload the DWC files like I do the firmware updates or is this a Duet Wifi only feature. I have the Duet 0.6.
If I can upload do I need the .bin file for the DWC firmware or something else?
DC42 Kossel 330mm x 2meters
My Thingiverse Creations
Re: DWC File Upload.
November 22, 2016 01:07PM
I've just been uploading the .zip file for the DWC, and it handles extracting everything in the right place as far as I can see on my Duet 0.8.5 boards.
November 22, 2016 01:17PM
Thanks. If it works on 0.8.5 it should do the same on mine. I will try it next time.
November 22, 2016 01:43PM
Make sure you upgrade the different parts in the correct order (DWC should be the last one to do)
So main Firmware then the WiFi server (If applicable) then the DWC if you upgrade the DWC to a version that is not compatible with the FW then you will have to revert to doing it with Bossac or Sam-ba depending on the board
HTH
Doug
