Minor firmware release 1.17d
January 28, 2017 01:06PM
This is now on github. The changes since 1.17c are:
New features:
  • G2 and G3 arc movement commands are implemented.
  • If the controller is reset because of a Hard Fault exception, additional debugging information is stored in the Software Reset Data and displayed by M122
  • Faster step pulse generation - now up to 180kHz simultaneously on 3 motors on the Duet WiFi
  • The M102 command (generated by S3D when using firmware retraction) is ignored instead of provoking a warning message
  • Firmware retraction/unretraction now defaults to 2.0/2.0 instead of 1.0/2.0 mm
Bug fixes:
  • If tool mixing was used with absolute extruder coordinates, the extrusion amount was calculated incorrectly.
  • The second SD card didn't work on Duet085 and RADDS builds
  • The [deprecated] M206 command takes account of whether the units are mm or inches
I also fixed a bug with absolute extruder coordinates introduced in temporary versions 1.17c+1 and +2.
Edited 1 time(s). Last edit at 01/28/2017 05:52PM by dc42.
Large delta printer [miscsolutions.wordpress.com], Robotdigg SCARA printer, Crane Quad and Ormerod
