thermostatic fan not starting properly February 13, 2017 12:22AM |
Re: thermostatic fan not starting properly February 13, 2017 02:46AM |
Re: thermostatic fan not starting properly February 13, 2017 04:46AM |
dc42
I suspect you are using a common positive supply wire to feed both the hot end heater and the fan, but you have used the heater negative terminal as the common wire instead of the heater positive terminal.
Re: thermostatic fan not starting properly February 13, 2017 08:29AM |
