2nd extruder offset February 13, 2017 08:13AM |
Re: 2nd extruder offset February 13, 2017 05:35PM |
Re: 2nd extruder offset February 14, 2017 01:22AM |
Re: 2nd extruder offset February 14, 2017 02:45AM |
Re: 2nd extruder offset February 14, 2017 04:44AM |
Re: 2nd extruder offset February 14, 2017 08:35AM |
Re: 2nd extruder offset February 14, 2017 09:26AM |
dc42
I didn't spot anything wrong with your config.g. Try this test:
Home the printer
Send T-1 to ensure no tool is selected
Send G1 X100. Web interface or M114 should show the X position as 100.
Send T0. Assuming you don't have any movement commands in your tool change files, the X position reported should now be 102.35.
Send T1. The X position should be reported as 97.35.
Re: 2nd extruder offset February 14, 2017 11:52AM |
Re: 2nd extruder offset February 14, 2017 12:11PM |
Re: 2nd extruder offset February 14, 2017 04:56PM |
Re: 2nd extruder offset February 15, 2017 03:59AM |
dc42
Here's another test then. Home the printer, send T0, then send the nozzle a particular place e.g. by sending G1 X100 Y100. Mark the point that the first nozzle is over. Then send T1, then G1 X100 Y100 again. The second nozzle should be over the same point.
dc42
One thing that could be messing it up is if you are X or Y homing on a tool change and you have G92 commands in your homing files. Don't use G92 in your homing files, use M208 and M208 S1 to define the homing positions of the head reference point instead. You don't need to do any homing on a tool change either.
Re: 2nd extruder offset February 15, 2017 06:56AM |
Re: 2nd extruder offset February 16, 2017 02:42AM |
