Finding Trigger Heights for Offsets
Posted by Kurzaa
February 26, 2017 03:45PM
I used to be able to run a G32 or G30 command that would probe all of my bed points and return the trigger heights for all of the points in the gcode console. However, the best solution I can find at the moment is probing a single bed point with a G30 S-1 which only returns one result. Seems to follow the instructions for calibrating delta printers on the Duet website.
Is the ability to multi-probe the bed no longer available? I might have read some upgrade notes along that thought process at one point.
Re: Finding Trigger Heights for Offsets
February 27, 2017 03:04AM
Assuming you are using a bed.g file for doing bed probing, take a copy of it and change the S parameter on the final G30 command in it to S-1.
February 27, 2017 09:58PM
That was it. Thanks for the help dc42.
