dc42 version - How to change lateral z-probe speeds?
Posted by shadowphile
March 05, 2017 10:31PM
During G30 commands I want to speed up those traverses, can't find a button or g-code anywhere, can you help?
thanks
Re: dc42 version - How to change lateral z-probe speeds?
March 06, 2017 01:14AM
See [reprap.org].
March 07, 2017 02:29AM
There is nothing in this command about speed and I can't find any other g-code that references this parameter. I inserted 'G1 F10000' before each G30 command but it made no difference. I seem to remember having access to these parameters somewhere (but that might be from my RAMPS days).
Usage
G30 Xnnn Ynnn Znnn Annn E R I D T S U
Parameters
Xnnn X coordinate
Ynnn Y coordinate
Znnn Z coordinate
Annn A Autocalibration width nnn precision
E Adjust Endstop
R Adjust Endstop & Delta Radius
I Adjust Tower
D Adjust Diagonal Rod
T Adjust Tower Radius
Sn Stows the probe if 1 (default=1)
Un with a non-zero value will apply the result to current zprobe_zoffset
March 07, 2017 02:55AM
Follow the link I posted and look at the description of the T parameter.
March 07, 2017 03:15AM
We seem to be on different planetsconfused smiley
Your link goes to the home page for the reprap gcode reference but not to anything specific. I also did not see anything there using a 'T' parameter except Tower Radius in the G30 command. What is the gcode I am supposed to look up?
thanks
March 07, 2017 06:27AM
Davids link does indeed take you to the Reprap Gcodes page but it homes in on M558 which is where you need to look (Or at least it does for me).
HTH
Doug
March 07, 2017 03:42PM
Ah, have not seen that before. (how does one link to a subsection of a page?)
thanks to all
This command also includes dive height and probe speed so this is really great!
March 08, 2017 02:58AM
"http://reprap.org/wiki/G-code#M558:_Set_Z_probe_type"
March 08, 2017 01:14PM
Thanks. Apparently I need to know HTML or something , which I don't. sad smiley
March 08, 2017 04:57PM
shadowphile
No you don't. To create a link to a subsection of a wiki page, find the entry for the subsection in the index near the start of the page. That is a link the subsection, so you can just right click on it and copy it. Or follow it, then copy the address from the address box of your browser.
If the link I posted didn't take you directly to the M558 section of the gcodes wiki page then I guess you were using a slow internet connection and you didn't wait for the page to finish loading.
