No web interface after upgrade from 1.16 to 1.18RC1 March 28, 2017 04:25PM |
FIRMWARE_NAME: RepRapFirmware for Duet FIRMWARE_VERSION: 1.18RC1 ELECTRONICS: Duet 0.85 FIRMWARE_DATE: 2017-03-28 ok
serial: M20 P/www Begin file list css favicon.ico.gz fonts html404.htm js language.xml.gz reprap.htm.gz End file list ok
Re: No web interface after upgrade from 1.16 to 1.18RC1 March 28, 2017 05:35PM |
Re: No web interface after upgrade from 1.16 to 1.18RC1 March 29, 2017 04:58AM |
Re: No web interface after upgrade from 1.16 to 1.18RC1 March 29, 2017 05:59AM |
Re: No web interface after upgrade from 1.16 to 1.18RC1 March 29, 2017 01:01PM |
Re: No web interface after upgrade from 1.16 to 1.18RC1 March 29, 2017 03:35PM |
Re: No web interface after upgrade from 1.16 to 1.18RC1 March 29, 2017 03:48PM |
Re: No web interface after upgrade from 1.16 to 1.18RC1 April 02, 2017 05:23AM |
Re: No web interface after upgrade from 1.16 to 1.18RC1 April 02, 2017 08:49AM |
serial: M122 LINK xmit: 607 recv: 1443 fw: 0 drop: 0 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 0 opterr: 0 err: 0 cachehit: 0 ETHARP xmit: 1 recv: 226 fw: 0 drop: 112 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 112 opterr: 0 err: 0 cachehit: 529 IP_FRAG xmit: 0 recv: 0 fw: 0 drop: 0 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 0 opterr: 0 err: 0 cachehit: 0 IP xmit: 579 recv: 1105 fw: 0 drop: 0 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 0 opterr: 0 err: 0 cachehit: 0 IGMP xmit: 0 recv: 0 drop: 0 chkerr: 0 lenerr: 0 memerr: 0 proterr: 0 rx_v1: 0 rx_group: 0 rx_general: 0 rx_report: 0 tx_join: 0 tx_leave: 0 tx_report: 0 ICMP xmit: 483 recv: 483 fw: 0 drop: 0 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 0 opterr: 0 err: 0 cachehit: 0 UDP xmit: 0 recv: 121 fw: 0 drop: 0 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 0 opterr: 0 err: 0 cachehit: 0 TCP xmit: 96 recv: 96 fw: 0 drop: 96 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 96 opterr: 0 err: 0 cachehit: 0 MEM HEAP avail: 1024 used: 0 max: 204 err: 0 MEM UDP_PCB avail: 5 used: 2 max: 2 err: 0 MEM TCP_PCB avail: 16 used: 0 max: 0 err: 0 MEM TCP_PCB_LISTEN avail: 4 used: 0 max: 0 err: 0 MEM TCP_SEG avail: 16 used: 0 max: 0 err: 0 MEM REASSDATA avail: 2 used: 0 max: 0 err: 0 MEM FRAG_PBUF avail: 8 used: 0 max: 0 err: 0 MEM IGMP_GROUP avail: 8 used: 1 max: 1 err: 0 MEM SYS_TIMEOUT avail: 8 used: 6 max: 6 err: 0 MEM PBUF_REF/ROM avail: 4 used: 0 max: 0 err: 0 MEM PBUF_POOL avail: 5 used: 0 max: 1 err: 0 === Diagnostics === Used output buffers: 1 of 32 (11 max) === Platform === Static ram used: 45844 Dynamic ram used: 39916 Recycled dynamic ram: 256 Stack ram used: 3240 current, 4372 maximum Never used ram: 7916 Last reset 00:08:01 ago, cause: power up Last software reset code not available Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 21.0MBytes/sec SD card longest block write time: 0.0ms MCU temperature: min 38.9, current 61.1, max 76.9 Date/time: 1970-01-01 00:00:00 Slowest main loop (seconds): 0.164490; fastest: 0.000244 === Move === MaxReps: 0, StepErrors: 0, MaxWait: 0ms, Underruns: 0, 0 Scheduled moves: 0, completed moves: 0 Bed compensation in use: none Bed probe heights: 0.000 0.000 0.000 0.000 0.000 === Heat === Bed heater = 0, chamber heater = -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Stack records: 1 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is ready with "M122" in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 Code queue is empty. === Network === Free connections: 16 of 16 Free transactions: 24 of 24 === Webserver === HTTP sessions: 0 of 8 FTP connections: 0, state 0 Telnet connections: 0, state 0 ok
Re: No web interface after upgrade from 1.16 to 1.18RC1 April 02, 2017 12:38PM |
Re: No web interface after upgrade from 1.16 to 1.18RC1 April 02, 2017 01:07PM |
Re: No web interface after upgrade from 1.16 to 1.18RC1 April 02, 2017 03:41PM |
serial: M115 FIRMWARE_NAME: RepRapFirmware for Duet FIRMWARE_VERSION: 1.18RC2+1 ELECTRONICS: Duet 0.85 FIRMWARE_DATE: 2017-04-02 ok
erial: M586 HTTP is enabled on port 80 FTP is enabled on port 21 TELNET is enabled on port 23
Re: No web interface after upgrade from 1.16 to 1.18RC1 April 02, 2017 05:18PM |
Re: No web interface after upgrade from 1.16 to 1.18RC1 April 02, 2017 06:05PM |
M111 S1 M550 P3dprint M551 Preprap M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED M552 P192.168.0.52 M554 P192.168.0.1 M553 P255.255.255.0 M555 P2 M575 P1 B57600 S1 M586 P1 S1 M586 P2 S1 M584 X5 Y6 E3:4:0:1:7:8 M569 P0 S1 M569 P1 S1 M569 P2 S0 M569 P3 S0 M569 P4 S1 M569 P5 S0 M569 P6 S0 M574 X2 Y1 Z0 S2 M574 E S1 M906 X700 Y900 Z900 E1100 I50 M201 X180 Y180 Z15 E1000 M203 X20000 Y20000 Z200 E2000 M566 X1000 Y1000 Z30 E90 M208 X330 Y300 Z300 M208 X0 Y0 Z0 S1 M92 X80 Y80 Z1600 M92 E146:146 G21 G90 M83 M558 P4 X0 Y0 Z1 H0.7 F100 T5000 G31 X16.0 Y-35 Z1.48 P500 M557 X20:320 Y20:280 S50 M143 S300 M570 S120 ;M140 H1 M305 P0 R4700 T100000 B4388 M305 P1 R4700 T92000 B4388 M305 P2 R4700 H0 L0 M307 H3 A-1 C-1 D-1 M307 H0 A200 C1220.7 D25 S1 B0 M307 H1 A1499.9 C209 D5 S0.6 B0 M563 P0 D0 H1 G10 P0 S0 R0 ;M563 P1 D1 H2 ;G10 P1 S0 R0 ; Epilogue M106 P0 F30 M106 P1 S250 F30 H1 T55 M572 D0 S0.08 M556 S75 X0 Y0 Z0.5 T0
Re: No web interface after upgrade from 1.16 to 1.18RC1 April 05, 2017 02:28PM |
Re: No web interface after upgrade from 1.16 to 1.18RC1 April 06, 2017 04:33PM |
serial: M122 LINK xmit: 72 recv: 340 fw: 0 drop: 0 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 0 opterr: 0 err: 0 cachehit: 0 ETHARP xmit: 0 recv: 7 fw: 0 drop: 100 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 100 opterr: 0 err: 0 cachehit: 68 IP_FRAG xmit: 0 recv: 0 fw: 0 drop: 0 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 0 opterr: 0 err: 0 cachehit: 0 IP xmit: 68 recv: 233 fw: 0 drop: 0 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 0 opterr: 0 err: 0 cachehit: 0 IGMP xmit: 0 recv: 0 drop: 0 chkerr: 0 lenerr: 0 memerr: 0 proterr: 0 rx_v1: 0 rx_group: 0 rx_general: 0 rx_report: 0 tx_join: 0 tx_leave: 0 tx_report: 0 ICMP xmit: 8 recv: 8 fw: 0 drop: 0 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 0 opterr: 0 err: 0 cachehit: 0 UDP xmit: 0 recv: 49 fw: 0 drop: 0 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 0 opterr: 0 err: 0 cachehit: 0 TCP xmit: 60 recv: 60 fw: 0 drop: 60 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 60 opterr: 0 err: 0 cachehit: 0 MEM HEAP avail: 1024 used: 0 max: 104 err: 0 MEM UDP_PCB avail: 5 used: 2 max: 2 err: 0 MEM TCP_PCB avail: 16 used: 0 max: 0 err: 0 MEM TCP_PCB_LISTEN avail: 4 used: 0 max: 0 err: 0 MEM TCP_SEG avail: 16 used: 0 max: 0 err: 0 MEM REASSDATA avail: 2 used: 0 max: 0 err: 0 MEM FRAG_PBUF avail: 8 used: 0 max: 0 err: 0 MEM IGMP_GROUP avail: 8 used: 1 max: 1 err: 0 MEM SYS_TIMEOUT avail: 8 used: 6 max: 6 err: 0 MEM PBUF_REF/ROM avail: 4 used: 0 max: 0 err: 0 MEM PBUF_POOL avail: 5 used: 0 max: 1 err: 0 === Diagnostics === Used output buffers: 1 of 32 (11 max) === Platform === Static ram used: 45844 Dynamic ram used: 39916 Recycled dynamic ram: 256 Stack ram used: 3240 current, 4372 maximum Never used ram: 7916 Last reset 00:01:03 ago, cause: power up Last software reset code not available Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 21.0MBytes/sec SD card longest block write time: 0.0ms MCU temperature: min 52.5, current 54.4, max 56.8 Date/time: 1970-01-01 00:00:00 Slowest main loop (seconds): 0.164471; fastest: 0.000267 === Move === MaxReps: 0, StepErrors: 0, MaxWait: 0ms, Underruns: 0, 0 Scheduled moves: 0, completed moves: 0 Bed compensation in use: none Bed probe heights: 0.000 0.000 0.000 0.000 0.000 === Heat === Bed heater = 0, chamber heater = -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Stack records: 1 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is ready with "M122" in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 Code queue is empty. === Network === Free connections: 16 of 16 Free transactions: 24 of 24 Locked: 0, state: 3, listening: 0x0, 0x0, 0x0 === Webserver === HTTP sessions: 0 of 8 FTP connections: 0, state 0 Telnet connections: 0, state 0
Re: No web interface after upgrade from 1.16 to 1.18RC1 April 07, 2017 02:17AM |
Re: No web interface after upgrade from 1.16 to 1.18RC1 April 07, 2017 09:22AM |
Re: No web interface after upgrade from 1.16 to 1.18RC1 April 07, 2017 03:41PM |
