Dual extrusion with Single extruder
Posted by selva_tvi
April 22, 2017 06:16AM
Recently I bought 2WAY in 1WAY out TL-Feeder Prusa bowden prometheus multi feeder System from Aliexpress. [www.aliexpress.com]
I am planning to use with DUET Wifi. Anybody has used this already? Any suggestion? What will be the tool change G-code
'Tool 0' will be retracted upto 100mm and then 'Tool 1' will be extruding 100mm. Then it will print the Prime pillar and again it will start the print.
Thanks
Selvakumaran
Re: Dual extrusion with Single extruder
April 22, 2017 03:11PM
Most of this is covered at [duet3d.com], in particular the sections on tool definition commands and tool change files.
Large delta printer [miscsolutions.wordpress.com], Robotdigg SCARA printer, Crane Quad and Ormerod
April 24, 2017 01:46AM
Thanks. I didn't search it properly. My apologies.
