Storing Calibration?
Posted by clearlynotstefan
June 02, 2017 11:53PM
My build and bed-mounting solution is stable enough that I suspect I don't need to be calibrating for each print. How do I go about storing the results of a S8 calibration though? I can update delta radius, height, etc but how to store endstop offsets and X (deg) Y(deg) etc?
Edited 1 time(s). Last edit at 06/02/2017 11:53PM by clearlynotstefan.
Re: Storing Calibration?
June 03, 2017 03:50AM
Send M500 after calibration. This will save the M665, M666, M307 and G31 parameters in file config-override.g. Then make sure that your config.g file invokes config-override.g at the end, which is done with command M501.
Alternatively, after running auto calibration, send M665 and M666 without parameters to see what values auto calibration has produced. Then edit those values into the M665 and M666 commands in config.g. The endstop corrections go in the XYZ parameters of the M66 command, and the tower angle corrections go in the M665 X and Y parameters.
