Connecting your Duet 0.85 Straight to Computers Ethernet
Posted by chris33
June 07, 2017 11:04AM
Ok i thought i would post this here for relevance and searchable material as i struggled myself to understand what i needed to do to run the duet 0.85 from the computer alone without no bridge or needing a router or cross over cable as my delta i wanted it to be able to take it places where there might not be router, now this as i believe will only work if your adapter has autoconfiguration,
To check i opened command prompt and typed in ipconfig/all look for this
Then i went to my settings opened the Ethernet tab/change adapter settings
Then right clicked Ethernet in network card go to properties
I highlighted internet protocol version 4 (tcp/ip4) and select use te following as i set my duet ip address as 192.168.0.31 so i put in one few numbers below
Im glad i got it too work as webcontrol user interface is probably best interface ive used to control a printer
Edited 2 time(s). Last edit at 06/07/2017 02:13PM by chris33.
Check my rubbish blog for my prusa i3
up and running
[3dimetech.blogspot.co.uk]
Re: Connecting your Duet 0.85 Straight to Computers Ethernet
June 07, 2017 05:37PM
Thanks for posting that guide!
