Setup:
Duet 0.6 board that was running successfully on v1.17e.
E3D v6 hot end (genuine!)
Problem:
Upgraded to 1.19 this morning, worked through the release notes and everything seems good - apart from when I try to autotune the hot end. It keeps coming back with the dreaded "Auto tune cancelled because target temperature was not reached". The command I used was
M303 H1 S250
I get the error as it approaches around 230C - 240C, even though I'm watching the temp steadily increasing right up to that point. I have also sent a separate command to set the temp to 280C and it achieved that without problems (although I did quit at around 270C).
I have tried sending
M307 H1 D60
as suggested in the documentation, but I still get the error.
I suspect that I'm doing something wrong - guidance would be appreciated!
UPDATE: M303 H1 S230 worked OK. Strange...
Edited 1 time(s). Last edit at 08/22/2017 06:24AM by David J.
