Extruder skipping steps? November 20, 2017 01:06PM |
Re: Extruder skipping steps? November 20, 2017 02:04PM |
Re: Extruder skipping steps? November 20, 2017 05:56PM |
Re: Extruder skipping steps? November 20, 2017 11:33PM |
Re: Extruder skipping steps? November 21, 2017 04:42AM |
Re: Extruder skipping steps? November 21, 2017 04:52AM |
Re: Extruder skipping steps? November 21, 2017 02:33PM |
Re: Extruder skipping steps? November 21, 2017 05:10PM |
Re: Extruder skipping steps? November 21, 2017 07:56PM |
Re: Extruder skipping steps? November 22, 2017 11:29AM |
Re: Extruder skipping steps? November 22, 2017 12:10PM |
Re: Extruder skipping steps? November 22, 2017 02:32PM |
Re: Extruder skipping steps? November 22, 2017 08:19PM |
Kevin37
Yes I did and now its working I used some extra aluminum to mill a mount. I'm assuming the way I had it mounted was putting to much pressure on the center of the motor. Im going to put it together ang switch all the wires back and do a test print later. I will report back later today or tomorrow to let you all know how it goes.
One good thing came out of all this, I was forces to do perfect cable managment and my printer looks amazing now! Thank you all for your help and I can't wait to see how my prints xom out!
Re: Extruder skipping steps? November 22, 2017 10:43PM |
Re: Extruder skipping steps? November 23, 2017 12:11PM |
Kevin37
At first when I took the stepper of the frame it still did the same thing, then I lowered the current back to 800 and it worked fine. I made a new mount and it was working flawless. Until I did my test print! Then it started again, I will proceed to checking the connector and the motor shaft and we will see what I come up with. I wil wait until Friday due to the holiday. I may just buy a high torque motor to replace it, all the others are and they seem to run fine.Thank you again for all the help and have a happy thanksgiving.
Re: Extruder skipping steps? November 23, 2017 12:38PM |
Re: Extruder skipping steps? November 23, 2017 01:41PM |
dc42
I just looked at your video again. Looks like you have clamped the body of the motor to an extrusion at the side of the motor. That's not a good idea. Unless the screws that hold the motor together are very tight, the body of the motor will move relative to the front and back, and the rotor may bind on the stator. I suggest you remove the filament and the lever arm, disconnect the motor, and then check whether the shaft turns freely.
Re: Extruder skipping steps? November 23, 2017 02:02PM |
dc42
Re: Extruder skipping steps? December 02, 2017 01:38AM |
Re: Extruder skipping steps? December 02, 2017 04:06AM |
Re: Extruder skipping steps? December 02, 2017 11:43AM |
dc42
Are you using the same cable with the new motor, or did it come with wires already attached? The problem has to be in the motor (which you have replaced), the driver (but you have tried the other driver output), or the cable and connector.
Re: Extruder skipping steps? December 03, 2017 11:37PM |
Re: Extruder skipping steps? December 04, 2017 03:12AM |
Re: Extruder skipping steps? December 04, 2017 07:56AM |
Re: Extruder skipping steps? December 04, 2017 11:21AM |
Re: Extruder skipping steps? December 12, 2017 10:23AM |
dc42
You need to define all the driver assignments using M584, see [duet3d.com]. Note, M584 does not change the endstop connector assignment, so you should leave the endstop wiring alone.[/quot]
Thank you for the help, I have not been able to mess with my printer due to my recent spinal surgery. I will give this a go when I am able to. I am also moving from Texas to Tennessee on the second of Jan. So I am on hold as far as the 3d printing.
I really appreciate all the help and will continue when I can and and post the results in a month or so. Thanks again
