PS_on signal low voltage November 30, 2017 04:04PM |
Re: PS_on signal low voltage November 30, 2017 04:21PM |
Re: PS_on signal low voltage November 30, 2017 06:35PM |
Re: PS_on signal low voltage December 01, 2017 02:38AM |
Roberts_Clif
This was setup for ATX power supplies and this is the signal they need to operate. (PS_ON#, green wire) which must be driven low to switch power supply on.
By what you have said, I would think you need a 4.7K pull-up resister.
And this is what you need
* Select your power supply here. Use 0 if you haven't connected the PS_ON_PIN
* 0 = No Power Switch
* 1 = ATX
* 2 = X-Box 360 203Watts (the blue wire connected to PS_ON and the red wire to VCC)
* :{ 0:'No power switch', 1:'ATX', 2:'X-Box 360' }
#define POWER_SUPPLY 2
#if (POWER_SUPPLY == 1) // 1 = ATX
#define PS_ON_AWAKE LOW
#define PS_ON_ASLEEP HIGH
#elif (POWER_SUPPLY == 2) // 2 = X-Box 360 203W
#define PS_ON_AWAKE HIGH
#define PS_ON_ASLEEP LOW
#endif
Re: PS_on signal low voltage December 01, 2017 04:20AM |
Re: PS_on signal low voltage December 01, 2017 04:25AM |
dc42
PS_ON is an open-drain output. So you need to connect the SSR positive control terminal to either +3.3 or +5V from the expansion connector, and the negative control terminal to the PS_ON pin.
Re: PS_on signal low voltage December 01, 2017 05:00AM |
DeltaCon
dc42
Thanks David,
Are you suggesting this?
[attachment 100080 5VtoSSR.jpg]
Re: PS_on signal low voltage December 04, 2017 01:08PM |
