Duet Ethernet Connection December 03, 2017 07:15PM |
. Today I had to reset the router and again the board would not connect to the web control. I had to power off the board and attach the USB cable to get the board to connect to the web control. Now it connects fine without the USB and under 24v power. Bug or??
Re: Duet Ethernet Connection December 04, 2017 03:03AM |
Re: Duet Ethernet Connection December 04, 2017 06:41PM |
Re: Duet Ethernet Connection December 05, 2017 03:06AM |
Re: Duet Ethernet Connection December 05, 2017 11:51AM |
Re: Duet Ethernet Connection December 06, 2017 08:29PM |
Re: Duet Ethernet Connection December 07, 2017 01:23AM |
jbolt
No I have not set a static IP. When the board won't connect I can query the IP address in Simplify3D via USB with M552 and it will show the router assigned IP but will not connect until I remove the 24vdc power. I am also using the recommended USB isolator for ground loops. I prefer not to have the USB hooked up at all since it applies power to the board when the main power is off.
If I set a static IP in the firmware do I need to reserve that IP in my router?
