controlled heated box December 18, 2017 05:35PM |
Re: controlled heated box December 19, 2017 01:05AM |
Re: controlled heated box December 19, 2017 01:57AM |
jbolt
How about a separate PSU for the heater(s) and use the second hot end mosfet to control a DC to DC SSR. That way you can also use the thermister port for the second hot end and have full duet control.
Re: controlled heated box December 19, 2017 09:08AM |
JustSumGuy
So I have this idea, might be too much to be worth it tho
I am building an enclosed HEVO and plan to install a heating system to maintain 50c-70c temp for ABS printing.
Duet Wifi btw...
The design is for a dual extruder single hotend setup. This will leave the second hotend PWM mosfet output and thermistor input unused.
I will be building for 24v so I was thinking if I used two 12v 50 watt heat elements in series then I should be able to control them from that mosfet output.
IF it can handle 100w that is.......
These are the heaters I am thinking about.
[www.aliexpress.com]
Re: controlled heated box December 20, 2017 12:21PM |
dc42
JustSumGuy
Duet Wifi btw...
Yes that sounds feasible, then you can use the M141 H2 command to configure that heater as a chamber heater.
Re: controlled heated box December 20, 2017 03:42PM |
Re: controlled heated box December 20, 2017 04:35PM |
