controlled heated box
Posted by JustSumGuy
December 18, 2017 05:35PM
So I have this idea, might be too much to be worth it tho smiling smiley
I am building an enclosed HEVO and plan to install a heating system to maintain 50c-70c temp for ABS printing.
Duet Wifi btw...
The design is for a dual extruder single hotend setup. This will leave the second hotend PWM mosfet output and thermistor input unused.
I will be building for 24v so I was thinking if I used two 12v 50 watt heat elements in series then I should be able to control them from that mosfet output.
IF it can handle 100w that is.......
These are the heaters I am thinking about.
[www.aliexpress.com]
If this is too much for it I can go for a 100w 12v one and use a second PSU just for the heater setup like this one:
with
The second idea would leave the Duet out of the equation fully and was my first thought btw, the idea to use the Duet is something I just thought of...
A fan would be circulating the air thru the heater element in both ideas of course smiling smiley
Any input smiling smiley
Thanx
Edited 3 time(s). Last edit at 12/18/2017 05:38PM by JustSumGuy.
Re: controlled heated box
December 19, 2017 01:05AM
How about a separate PSU for the heater(s) and use the second hot end mosfet to control a DC to DC SSR. That way you can also use the thermister port for the second hot end and have full duet control.
December 19, 2017 01:57AM
jbolt
but I have no intention of having a second hot end.
as far as an SSR and secondary PSU yes thats also doable, not needed if the one on board can handle 100 watt tho....
December 19, 2017 09:08AM
JustSumGuy
Duet Wifi btw...
Yes that sounds feasible, then you can use the M141 H2 command to configure that heater as a chamber heater.
December 20, 2017 12:21PM
dc42
JustSumGuy
Duet Wifi btw...
Just to confirm pls DC42, that mosfet can handle 100w ? I want to be sure as hotends are 40w and sometimes 50w I don't want to push this mosfet too hard.
Thanx
December 20, 2017 03:42PM
The limiting component is the terminal block, not the mosfet. I forget its rating, but it should be good to at least 6A, which is 120W @ 24V.
December 20, 2017 04:35PM
dc42
ok, that sounds like a way to go then smiling smiley
tqvm
