My proximity sensor endstops not working
Posted by chichirod
December 31, 2017 11:09AM
I have a Tevo Black widow which I just converted over from the MKS Gen V1.4 board to a duet Wifi. Im having all sorts of issues but lets just focus on the endstops. I have gone through the configuration tool a few times and tried different settings but nothing seems to work. I am 99.9% sure that I have the wiring hooked up correctly. When I hit the m119 command I get this: Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stoppedok
The endstops do not seem to light up at any point whether I put something metallic in front of them or not. I would very much appreciate any help someone can offer.
P.S. If you see anything else in the files that looks out of place I would really like the advice.
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool on Sun Dec 31 2017 08:13:05 GMT-0700 (Mountain Standard Time)
G91 ; relative positioning
G1 Z5 F6000 ; lift Z relative to current position
G1 S1 X-405 Y-255 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 X5 Y5 F6000 ; go back a few mm
G1 S1 X-405 Y-255 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X15 Y15 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed
;G1 Z5 F100 ; uncomment this line to lift the nozzle after homing
; Configuration file for Duet WiFi (firmware version 1.20 or newer)
; executed by the firmware on start-up
; General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
G90 ; Send absolute coordinates...
M83 ; ...but relative extruder moves
M555 P2 ; Set firmware compatibility to look like Marlin
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Configure automatic saving on power loss
M208 X0 Y0 Z0 S1 ; Set axis minima
M208 X400 Y250 Z300 S0 ; Set axis maxima
; Endstops
M574 X1 Y1 S0 ; Set active low endstops
M574 Z1 S2 ; Set endstops controlled by probe
M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
G31 P500 X0 Y0 Z5 ; Set Z probe trigger value, offset and trigger height
M557 X15:385 Y15:235 S20 ; Define mesh grid
; Drives
M569 P0 S1 ; Drive 0 goes forwards
M569 P1 S1 ; Drive 1 goes forwards
M569 P2 S1 ; Drive 2 goes forwards
M569 P3 S1 ; Drive 3 goes forwards
M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation
M92 X80 Y80 Z4000 E420 ; Set steps per mm
M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
M906 X1300 Y1300 Z1300 E1300 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout
; Heaters
M305 P0 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 0
M143 H0 S120 ; Set temperature limit for heater 0 to 120C
M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C
; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C
; Network
M550 PBlack Widow ; Set machine name
M552 S1 ; Enable network
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet
; Fans
M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
; Custom settings are not configured
open | download - IMG_4907.jpg (147.1 KB)
open | download - IMG_4909.jpg (81 KB)
Re: My proximity sensor endstops not working
December 31, 2017 11:35AM
As this endstop LEDs are never lit, this suggests two possibilities:
1. A wiring error. Note that the order of the 3 endstop pins on the Duet is not the same as on most 8-bit boards.
2. You are supplying the proximity sensors with 3.3V from the endstop connector, but they need 5V to operate.
Delta printer calibration calculator, mini IR Z probe, and colour touch screen control panel: [escher3d.com]
Large delta printer, and other 3D printer blog postings: [miscsolutions.wordpress.com]
Disclosure: I have a financial interest in sales of the Panel Due, Mini IR height sensor, and Duet WiFi/Duet Ethernet [www.duet3d.com].
December 31, 2017 11:39AM
PS - I suggest you search for "tevo black widow" at [www.duet3d.com] because other people seem to have done this conversion successfully.
December 31, 2017 12:14PM
Thanks DC42, for the super quick response. I believe I have taken into account the different order of the pins on the duet in comparison to the MKS. ( I will double check to make sure) Is there somewhere else on the Duet that I could connect to in order to get the 5v. I did look at the site you pointed out and researched the TEVO BLACK WIDOW. It talks about connecting a diode? this is getting into some unfamiliar ground for me. I will definitely have to do some more reading. Thanks. P.S. When the Duet is powered up, what lights should all bit lit up on it. I will attach a pic of mine
open | download - IMG_4910.jpg (160.2 KB)
December 31, 2017 12:32PM
The red 5V and green 3.3V LEDs should be lit, also the red 5V USB light if it is receiving USB power and the blue LED if it is receiving VIN power. The Diag LED may or may not be lit depending on configuration.
May I suggest that you request an account on the duet3d forum and ask questions there. That forum is a lot more active than this one and has other Duet+Tevo users.
December 31, 2017 12:34PM
Hi DC42 i tried to register for an account on that site but it stated not accepting any new registrations.
Never mind I see where I can Email to try and get set up.
Edited 1 time(s). Last edit at 12/31/2017 12:40PM by chichirod.
December 31, 2017 01:27PM
chichirod
If you look at the welcome message in the heading, it says to send an email to request an account. Unfortunately we were getting too much automated spam on the forum, so we had to suspend self-registration. We'll be moving to different forum software soon.
