Duet WiFi temperatures are too low. January 21, 2018 04:24AM |
; Configuration file for Duet WiFi (firmware version 1.20 or newer) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool on Sun Jan 14 2018 12:18:53 GMT+0100 (Mitteleuropäische Zeit) ; General preferences M111 S0 ; Debugging off G21 ; Work in millimetres G90 ; Send absolute coordinates... M82 ; ...and extruder moves M555 P2 ; Set firmware compatibility to look like Marlin ; Automatic saving after power loss is not enabled ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration. M665 R94 L217.5 B90 H280 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them M208 Z0 S1 ; Set minimum Z ; Endstops M574 X2 Y2 Z2 S1 ; Set active high endstops M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds G31 P400 X0 Y0 Z8.4 ; Set Z probe trigger value, offset and trigger height M557 R70 S20 ; Define mesh grid ; Drives M569 P0 S0 ; Drive 0 goes backwards M569 P1 S0 ; Drive 1 goes backwards M569 P2 S0 ; Drive 2 goes backwards M569 P3 S0 ; Drive 3 goes backwards M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation M92 X100 Y100 Z100 E99 ; Set steps per mm M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min) M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min) M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E950 I40 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Heaters M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0 M143 H0 S125 ; Set temperature limit for heater 0 to 125C M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1 M143 H1 S280 ; Set temperature limit for heater 1 to 280C ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Network M550 PDelta-WiFi ; Set machine name M552 S1 ; Enable network M586 P0 S1 ; Enable HTTP M586 P1 S1 ; Enable FTP M586 P2 S1 ; Enable Telnet ; Fans M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Custom settings are not configured M579 X1.01 Y1.01 M572 D0 S0.15
Re: Duet WiFi temperatures are too low. January 22, 2018 04:20AM |
Re: Duet WiFi temperatures are too low. January 22, 2018 10:45AM |
Re: Duet WiFi temperatures are too low. January 28, 2018 06:12AM |
Re: Duet WiFi temperatures are too low. January 28, 2018 08:58AM |
