Problem with BLTouch after upgrading to Firmware 1.20
Posted by drmaestro
February 10, 2018 01:37PM
I have been using Duet 3D and BLTouch together for at least a year without a problem. Today I have decided to upgrade my firmware (from 1.18 to 1.20) and my BLTouch is not working as it should now. The main problem is that the Z axis doesn't stop when BLTouch is triggered and crashes into the bed.
I didn't change any wiring and checked to see that they are firmly plugged in.
I can use M401 and M402 to deploy and retract the pin.
I can check on the test mode that a value of 1000 is shown when the probe is triggered and a value of 0 when it is deployed.
I really don't know what could be responsable for this behaviour, other than a change in how the firmware handles Z probes.
Does anyone run firmware 1.19 or 1.20 with BLTouch without a problem?
Re: Problem with BLTouch after upgrading to Firmware 1.20
February 10, 2018 04:03PM
Is this happening during Z homing? If so then most likely you have your homing files configured to use a Z homing switch instead of a Z probe. See #1 at [duet3d.com].
Large delta printer [miscsolutions.wordpress.com], Robotdigg SCARA printer, Crane Quad and Ormerod
