Additional fan on Duet board 0.6
Posted by swaroop
April 10, 2018 08:47AM
Hi to all,
I have Duet board 0.6 and I want to add fan controlled. I can use expansion header pins in duet board 0.6?
Re: Additional fan on Duet board 0.6
April 10, 2018 04:10PM
There is already one controlled fan output on the Duet 0.6 so I presume you mean you want to add a second one.
You would need to pick an unused heater pin on the expansion bus, connect an external MOSFET to it to drive the fan, and rebuild the firmware with a modified Pins_Duet.h file to allocate that pin to a fan instead of a heater.
Edited 1 time(s). Last edit at 04/10/2018 04:11PM by dc42.
April 11, 2018 02:47AM
Hi dc42,
I am new to duet board. and i want to know where is the Pins_Duet.h is located and also what changes i have to make in sys folder? please help me in detailed?
April 11, 2018 04:28PM
Pins_Duet.h is at [github.com]. Documentation for files in the /sys folder of the SD card is in the wiki at duet3d.com.
June 26, 2018 08:08AM
Hi dc42,
Thanks dc42.
