G-Code Files Web Interface.
Hello One and All.
I have noticed on my system that when I upload a file via the Curl Command--------------
curl -F "file=@[output_filepath]" "http://XXX.XXX.XXX.XXX/rr_upload?name=gcodes/[output_filename].gcode" it does not show up in the G-Codes Files section until I go up a directory and then back down. It appears to not refresh its Dir structure on the SD card. This may well be by design. Is there a way to achieve a refresh without having to manually Dir up Dir Down to do it?
Thank you.
