G-Code Files Web Interface
Posted by Dunston-UK
April 18, 2018 02:38PM
G-Code Files Web Interface.
Hello One and All.
I have noticed on my system that when I upload a file via the Curl Command-------------- curl -F "[email protected][output_filepath]" "http://XXX.XXX.XXX.XXX/rr_upload?name=gcodes/[output_filename].gcode" it does not show up in the G-Codes Files section until I go up a directory and then back down. It appears to not refresh its Dir structure on the SD card. This may well be by design. Is there a way to achieve a refresh without having to manually Dir up Dir Down to do it?
Thank you.
Re: G-Code Files Web Interface
April 18, 2018 03:11PM
If you mean it doesn't show up in Duet Web Control, there is a Refresh icon (two arrows that form a circle) that you can click to refresh the file list.
Edited 1 time(s). Last edit at 04/18/2018 03:12PM by dc42.
Delta printer calibration calculator, mini IR Z probe, and colour touch screen control panel: [escher3d.com]
Large delta printer, and other 3D printer blog postings: [miscsolutions.wordpress.com]
Disclosure: I have a financial interest in sales of the Panel Due, Mini IR height sensor, and Duet WiFi/Duet Ethernet.
April 18, 2018 03:19PM
dc42
DOH!
Thank you.
