Duet 2 Maestro launched April 24, 2018 04:48PM |
Re: Duet 2 Maestro launched April 25, 2018 03:35AM |
Re: Duet 2 Maestro launched April 25, 2018 01:48PM |
Re: Duet 2 Maestro launched April 26, 2018 03:08AM |
Re: Duet 2 Maestro launched April 29, 2018 03:23PM |
Re: Duet 2 Maestro launched April 30, 2018 01:52AM |
Re: Duet 2 Maestro launched May 01, 2018 12:09PM |
Re: Duet 2 Maestro launched May 01, 2018 01:15PM |
Re: Duet 2 Maestro launched May 21, 2018 03:11PM |
Re: Duet 2 Maestro launched May 21, 2018 06:08PM |
Re: Duet 2 Maestro launched May 22, 2018 02:43AM |
Re: Duet 2 Maestro launched June 07, 2018 09:49PM |
Re: Duet 2 Maestro launched June 08, 2018 11:01AM |
Re: Duet 2 Maestro launched June 09, 2018 02:37AM |
fitforlaunch_page
BETA TESTERS WANTED
As Duet3D and M3D are testing the boards on their own, we also have some early demo units to send to beta testers and reviewers, as well as 3D printing influencers who have experience with evaluation of technical products.
Re: Duet 2 Maestro launched June 09, 2018 03:33AM |
o_lampe
fitforlaunch_page
BETA TESTERS WANTED
Asking explicitly for influencers leaves a foul taste ....
Although they are asked for their "true" opinion, they are more like "cheerleaders". One bad review and they never get invited again....
Re: Duet 2 Maestro launched June 13, 2018 03:31PM |
Re: Duet 2 Maestro launched June 14, 2018 01:26AM |
Re: Duet 2 Maestro launched June 25, 2018 02:07AM |
Re: Duet 2 Maestro launched June 25, 2018 02:26AM |
Re: Duet 2 Maestro launched June 29, 2018 06:15PM |
Re: Duet 2 Maestro launched June 30, 2018 10:45AM |
Re: Duet 2 Maestro launched July 13, 2018 04:27PM |
o_lampe
Two month after announcement, I just visited the fitforlaunch page again and saw the first batches are still not sold ( 22% for the 2month delivery and 17% for the 1month delivery date )
I didn't expect that!?
This board doesn't meet peoples expectations it seems?
1)What are they missing?
1)WiFi
2)Stall detection/ sensorless homing
3)Beefy stepper drivers
4)A set of crimp connectors and housings ( retail package is sold out long ago or they took it from their page for unknown reasons)
5)Postage to EU to expensive?
Are there any early reviews I haven't seen here, keeping people from jumping on the train?
Re: Duet 2 Maestro launched July 14, 2018 01:55AM |
xrodney
A lower current limit for stepper drivers is a thing that's bit worries me, as my current board with a4988 driver which I believe is 1.3A seems to be on a limit to handle existing 1.68A steppers at higher speeds and I got new steppers for an upgrade that are rated at 2.0A.
Switching to 24V would probably help there but that would mean to get new PSU and all heaters at least as current ones are 12V.
As for postage, it depends, main problem is the additional cost that pile up localy, with $20-30 postage it gets almost more expensive than Duet Wifi.
Re: Duet 2 Maestro launched July 14, 2018 03:41AM |
dc42
I have run the Duet Maestro at up to 1.4A, with a 40mm fan to cool the Duet. So the maximum current you can use is comparable or perhaps just a little lower than you can use with plug-in A4988 drivers. The big advantages are that you know what current you are getting (because you set it in firmware), and the firmware warns you if the drivers are getting too hot well before they cut out and you lose steps.
Czech RepublicQuote
dc42
Which country are you in? It won't be long before we start shipping them from the UK.
Re: Duet 2 Maestro launched July 14, 2018 04:50AM |
Re: Duet 2 Maestro launched July 15, 2018 03:12PM |
Thank you for the explanation.Quote
dc42
The 17HS19-2004 is a good choice of motor to use with the Duet WiFi/Ethernet, but 17HS19-1684 would be a better choice for most other controllers, including the Maestro and controllers using plug-in A4988 drivers. Controllers using the TMC2130 should be used with motors having an even lower current rating.
Many 3D printers run the stepper motors at only 60% of rated current, which would be 1.2A for your motors. So you would still get reasonable performance from them at 1.2A, just a bit less low-speed torque than they are capable of. At 1.4A you would be running them at 70% of rated current, which may be as high as you want to go anyway to avoid the motors getting hot.
The 1.4A current that was quoting is peak current per phase, because in 3D printing it has always been the custom to quote peak stepper motor current. The TMC datasheets all quote RMS currents. Multiply the RMS current by 1.414 to get the peak current.
HTH David
Re: Duet 2 Maestro launched July 16, 2018 02:36AM |
Re: Duet 2 Maestro launched July 16, 2018 05:24AM |
dc42
Increasing driver supply voltage does not increase torque at low speeds (unless the motors have very high resistance), but does allow torque to be maintained up to higher speeds. There is a calculator to evaluate the effect of driver supply voltage at reprapfirmware.org.
If you want to run the fans at 12V you will need to supply 12V power directly to the positive fan wires. 24V fans are inexpensive.
Re: Duet 2 Maestro launched July 16, 2018 06:04PM |
Re: Duet 2 Maestro launched July 23, 2018 03:44PM |
