Re: Duet 2 Maestro launched August 20, 2018 08:59AM |
Re: Duet 2 Maestro launched August 20, 2018 09:39AM |
Re: Duet 2 Maestro launched October 31, 2018 02:46AM |
Re: Duet 2 Maestro launched November 29, 2018 05:46PM |
xrodney
Part of lost torque can be gain by switching from 12V to 24V, but that means I need to change few things.
Any recommendation for good 24V power supply (if possible silent)? I guess 480W or so should be sufficient for everything including 200-280W heated bed and 1-2 30-40W hotends?
As for fans, any chance to run them on 12V? Description on Maestro page is a bit vague in this case mentioning 5V or VIN (24V) but also mention other voltages can be used but I am not sure how?
Re: Duet 2 Maestro launched November 30, 2018 02:09AM |
For 5V fans you may use a 12v to 5v step-down-converter in the old 12v PSU. Same principle as before: +wire of fan directly to +5v of the step-down-converter, -wire of the fan to -fan-out on the Duet.
