Duet uSDHC socket
May 08, 2018 09:51PM
I have a damaged uSDHC socket on a Duet V0.6.
Does anyone have a Part# or link to where I can find a compatible replacement?
Re: Duet uSDHC socket
May 09, 2018 12:05AM
Better luck contacting duet support directly or asking on the duet forums.
May 09, 2018 11:09AM
phaedrux
Probably good advice.smileys with beer I suppose it was a shot in the dark to hope that someone here might be able to help.
Looking through Farnell, Digikey and Mouser I have been totally surprised by the number of SD card socket variations - I honestly would never have guessed that there would be so many differences considering that SD cards all have the same pinouts! winking smiley
I believe this is the one they use, I should say same design....
examine it carefully to be sure but it is cheap enough that not much loss if its wrong smiling smiley
finding the right person with the right equipment to do the solder work is likely to be VERY important tho....
[www.aliexpress.com]
There are a few designs to choose from:
Edited 2 time(s). Last edit at 05/09/2018 11:11AM by JustSumGuy.
May 09, 2018 11:29AM
JustSumGuy
Thanks!smiling smiley
I can't see a datasheet - but I'll give it a try. I found this board at a flea market and bought it for next to nothing so it would be nice to get it up and running.
May 09, 2018 12:40PM
This one [www.aliexpress.com] looks the closest match to me.
Which country are you in?
Edited 1 time(s). Last edit at 05/09/2018 12:42PM by dc42.
May 10, 2018 01:57AM
Isn't there a BOM list with part numbers? That's what Open Source Hardware is all about.
May 10, 2018 12:17PM
good point o_lampe.. i did not think of that...
I don't know where to look on that tho, perhaps dc42 can direct on that.
Edited 1 time(s). Last edit at 05/10/2018 12:18PM by JustSumGuy.
May 10, 2018 05:35PM
We do publish the BOM, it's part of the KiCAD project and can be generated in KiCAD.
The part number for the SD socket in the project is DM3AT-SF-PEJM5, however I think we have been using a slightly different socket with the same footprint - see my earlier reply.
