DC42--Small suggestion, if I may.. May 24, 2018 01:37AM |
Re: DC42--Small suggestion, if I may.. May 24, 2018 01:58AM |
Re: DC42--Small suggestion, if I may.. May 24, 2018 02:21AM |
Re: DC42--Small suggestion, if I may.. May 24, 2018 04:38AM |
Re: DC42--Small suggestion, if I may.. May 24, 2018 12:04PM |
Re: DC42--Small suggestion, if I may.. May 24, 2018 01:19PM |
Diggrr
NEMA23 5A 3Nm. I'm building a metal cutting mill soon.
Currently building a wood carving mill with 3A 1.9Nm steppers, and they should do well on my SBD109A's.
It's not all about current rating though, I'd prefer to use 48V power for more accurate stepping at higher rates.
Power requirements increase quickly when using meter long16mm+ ball screws.
Re: DC42--Small suggestion, if I may.. May 27, 2018 11:13PM |
Re: DC42--Small suggestion, if I may.. May 28, 2018 02:06AM |
Diggrr
Okay, so what exactly is the calculator showing me?
I have to set travel at 4mm/s @ 24V/2.2A to make all the fields green in the box below, which would seem quite slow.
The stepper calculator here Allaboutcircuits shows I should hit a more proper 52.5mm/s.
Thank you for your time BTW
Re: DC42--Small suggestion, if I may.. May 28, 2018 03:40AM |
Re: DC42--Small suggestion, if I may.. May 29, 2018 01:48AM |
Re: DC42--Small suggestion, if I may.. May 29, 2018 03:13AM |
Re: DC42--Small suggestion, if I may.. June 17, 2018 06:31AM |
Re: DC42--Small suggestion, if I may.. June 17, 2018 04:20PM |
