Panel Due 5" extended keyboard
Posted by Dunston-UK
June 13, 2018 01:44PM
When trying to use the console in Panel Due 5" I am unable to find the | symbol. Is this correct because if so then why have a console where you cant use extended symbols that are required in reprap.
Edited 1 time(s). Last edit at 06/13/2018 01:44PM by Dunston-UK.
Re: Panel Due 5" extended keyboard
June 14, 2018 12:16AM
On my german keyboard the "|" sign is on the same key as "<>". But it looks more like a dotted line.
June 14, 2018 01:32AM
Why do you need the vertical-bar symbol? It isn't needed in any GCodes, unless you have that character in a filename, SSID or password.
Delta printer calibration calculator, mini IR Z probe, and colour touch screen control panel: [escher3d.com]
Large delta printer, and other 3D printer blog postings: [miscsolutions.wordpress.com]
Disclosure: I have a financial interest in sales of the Panel Due, Mini IR height sensor, and Duet WiFi/Duet Ethernet.
June 15, 2018 02:31AM
its needed for the |1 command, as in M280 P3 S10 |1
June 16, 2018 06:59AM
Dunston-UK
The character you need in that command is not vertical bar, it is upper case letter-i. They look quite similar in some typefaces.
Edited 1 time(s). Last edit at 06/16/2018 07:00AM by dc42.
