How to connect laser to duet 6
Posted by appjaws1
July 11, 2018 05:37AM
I have bought this laser and control module and need help to connect it to a duet 6 for the best results.
What do I need to include in config file.
thanks for any help
appjaws - Core XYUV Duet Ethernet Duex5
firmware 3.1.1 Web Interface 3.1.1
Ormerod 1-converted to laser engraver, Duet wifi
OpenSCAD version 2020.07
slic3r-1.3.0, Simplify3D 4.1.2, Cura-4.4.1
Re: How to connect laser to duet 6
July 11, 2018 06:18AM
You may find this thread useful [forum.duet3d.com].
July 11, 2018 06:59AM
Thanks for the link, I had already looked at that and have ordered a 74HCTo2.
Can I use the bed heater or the extruder heater or the extruder motor instead of heater 3?
If so what do I enter in config?
Thanks
July 12, 2018 02:21AM
Yes you can use any of the heater outputs or the fan output. See the page on the Duet3d wiki about controlling servos and unused i/o pins.
Edited 1 time(s). Last edit at 07/12/2018 02:21AM by dc42.
July 12, 2018 11:45AM
Thanks again for the information.
I see that some heater channels on the expansion boards are active high, are any of the heaters bed, hot end, or fan outputs PWM active high on the main duet 6 board?
thanks for your help
July 12, 2018 02:22PM
Al the heater outputs are active low. The reason is that the outputs of the SAM3X processor have pullup resistors enabled by default, so the default state is high. So active low is safer.
