Enclosure Heater on Duex2
Posted by rikesh942014
July 17, 2018 02:59PM
Hi guys,
I want to mount a Enclosure heater for my 3D printer and was wondering if the Duex2 Expansion board is able to power this through the extruder heaters.
I have read somewhere that the Duet Wifi is able to go upto about 9Amps for the extruder heaters but couldn't find much information for the Duex2 boards.
Enclosure heater that I am using: [www.ebay.co.uk]
So the heater is 24V at 150W - which would be about 6.25Amps, can anyone confirm if this is okay to power through the extruder heaters on the Duex2 expansions board.
Re: Enclosure Heater on Duex2
July 17, 2018 05:12PM
We normally say 5A maximum for Duet heater outputs, however the mosfets and connectors can handle more than that. So I think 6.25A should be OK. The weakest point is probably the vias connecting the mosfet source terminal to the ground plane.
Edited 1 time(s). Last edit at 07/17/2018 05:13PM by dc42.
