Homing Z Axis September 28, 2018 08:50AM |
G28 Z Error: G0/G1: insufficient axes homed
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool on Wed Sep 26 2018 11:15:59 GMT+0100 (GMT Daylight Time) G91 ; relative positioning G1 Z5 F6000 S2 ; lift Z relative to current position G90 ; absolute positioning G1 X20 Y20 F6000 ; go to first probe point G30 ; home Z by probing the bed ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 S2 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
Re: Homing Z Axis September 28, 2018 09:56AM |
Re: Homing Z Axis September 28, 2018 10:24AM |
Re: Homing Z Axis September 28, 2018 10:44AM |
; homez.g ; called to home the Z axis G91 ; Relative Positioning G1 Z5 F6000 S2 G90 ; Absolute Positioning G1 X110 Y137.5 G30
; Endstops M574 X2 Y2 S0 ; Set active low endstops ; Z-Probe M574 Z1 S2 ; Set endstops controlled by probe M558 P8 H8 F780 I1 T9000 R0.8 Z1 ; Set Z probe type to unmodulated and the dive height + speeds G31 X0 Y0 Z-0.1 P100 ; Set Z probe trigger value, offset and trigger height M557 X50:170 Y35:235 S40 ; Define mesh gridThe 2 M574 commands set the X and Y endstops to max positions, active low, then set up the Z probe as the Z endstop.
Re: Homing Z Axis September 28, 2018 11:06AM |
dc42
G30 requires X and Y to be homed but not Z. The message in the original post indicates that is was a G1 command that was failing.
You will need to have X and Y already homed for the homez.g file to work.
G30 Error: G0/G1: insufficient axes homed
Re: Homing Z Axis September 28, 2018 11:21AM |
; Endstops M574 X1 Y1 S0 ; Set active low endstops ; Z-Probe M574 Z1 S2 ; Set endstops controlled by probe M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds G31 P500 X0 Y0 Z1.5 ; Set Z probe trigger value, offset and trigger height M557 X20:200 Y20:200 S20 ; Define mesh grid
Re: Homing Z Axis September 28, 2018 12:02PM |
Re: Homing Z Axis September 28, 2018 12:22PM |
Re: Homing Z Axis September 28, 2018 03:10PM |
Re: Homing Z Axis September 28, 2018 04:18PM |
Re: Homing Z Axis September 28, 2018 04:59PM |
dc42
Do you have deployprobe.g and retractprobe.g files on the SD card that you didn't create yourself? If so, delete them. Later firmware versions run them automatically when you send G30.
