Re: need help on configuring new thermistor January 22, 2019 11:47AM |
Brummie
With my current setup I can print a 20mm cube in spiral mode at 120mm/s and result is ok.
As soon as I turn off spiral mode, print failures arise on all ends.
Re: need help on configuring new thermistor January 23, 2019 12:38AM |
Sure!Quote
Have you calibrated the extruder steps/mm?
I try to avoid sophisticated stuff, that I don't understand. So, no!Quote
Are you using pressure advance?
I started calibration with retract 0 and 100mm/s (same speed on all speed categories, except traveling, which is 300mm/s)Quote
What were the problems?
Re: need help on configuring new thermistor January 23, 2019 03:04AM |
Re: need help on configuring new thermistor January 23, 2019 03:32AM |
