Duet 2 wifi 12v in 24v bed December 26, 2018 08:05AM |
Re: Duet 2 wifi 12v in 24v bed December 26, 2018 08:47AM |
Re: Duet 2 wifi 12v in 24v bed December 26, 2018 08:52AM |
Re: Duet 2 wifi 12v in 24v bed January 02, 2019 03:32PM |
Re: Duet 2 wifi 12v in 24v bed January 03, 2019 04:06AM |
Re: Duet 2 wifi 12v in 24v bed January 03, 2019 11:19AM |
dc42
As @SupraGuy says, using 24V VIN will potentially give you higher travel speeds, and is essential IMO if you use 0.9deg motors. Personally I use 24V for everything; however some users prefer Noctua fans because they are quiet, and those are not available in 24V. So a good solution is to use 24V for everything except the fans, and to use a 12V buck converter for the fans. If the hot end on your printer uses a cartridge heater (as almost all do) then it should be easy to replace it by a 24V cartridge.
