z-homing failed with mini IR March 24, 2019 05:23AM |
; Drives M569 P0 S0 ; Drive 0 goes backwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M569 P4 S1 ; Drive 4 goes forwards M584 X0 Y1 Z2:4 ; Assign drives M593 F25 ; cancel ringing at 40.5Hz M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E415 ; Set steps per mm M566 X480.00 Y480.00 Z90.00 E300.00 ; Set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z900.00 E3000.00 ; Set maximum speeds (mm/min) M201 X1500.00 Y1500.00 Z500.00 E250.00 ; Set accelerations (mm/s^2) M906 X900.00 Y900.00 Z1200.00 E800.00:1200 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; set coordinates of leadscrews M671 X-27:262 Y117.5:117:5 M208 X0:235 Y-2:228 ; Axis Limits M208 X-5 Y-10 Z0 S1 ; Set axis minima M208 X235 Y235 Z250 S0 ; Set axis maxima ; Endstops M574 X1 Y1 S1 ; Set active high endstops M574 Z0 S0 ; Z-Probe M558 P1 H5 F120 T6000 ; Set Z probe type to switch and the dive height + speeds G31 P500 X-5 Y20 Z3.547 ; Set Z probe trigger value, offset and trigger height M557 X10:225 Y15:210 S20 ; Define mesh grid
; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by RepRapFirmware Configuration Tool v2 on Mon Dec 24 2018 14:30:36 GMT+0100 (Mitteleuropäische Normalzeit) G28 G30 P0 X200 Y110 Z-99999 ; probe near a leadscrew, half way along Y axis G30 P1 X15 Y110 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v2 on Mon Dec 24 2018 14:30:37 GMT+0100 (Mitteleuropäische Normalzeit) G91 ; relative positioning G1 Z5 F6000 S2 ; lift Z relative to current position G30 P0 X200 Y110 Z-99999 ; probe near left-hand leadscrew G30 P1 X15 Y110 Z-99999 S2 ; probe near right-hand leadscrew and calibrate 2 motors ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 S2 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
Re: z-homing failed with mini IR March 24, 2019 05:23PM |
Re: z-homing failed with mini IR March 24, 2019 05:49PM |
Re: z-homing failed with mini IR March 25, 2019 03:01AM |
Re: z-homing failed with mini IR March 25, 2019 06:25AM |
Re: z-homing failed with mini IR March 25, 2019 07:41AM |
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v2 on Mon Dec 24 2018 14:30:37 GMT+0100 (Mitteleuropäische Normalzeit) G91 ; relative positioning G1 Z5 F6000 S2 ; lift Z relative to current position G1 S1 X-240 Y-245 F2400 ; move quickly to X and Y axis endstops and stop there (first pass) G1 X5 Y5 F6000 ; go back a few mm G1 S1 X-240 Y-245 F360 ; move slowly to X and Y axis endstops once more (second pass) G90 ; absolute positioning G1 X122 Y110 F6000 G30 ; probe the bed using z probe to find Z0 G1 Z10 F5000 ; raise z to 10
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v2 on Mon Dec 24 2018 14:30:37 GMT+0100 (Mitteleuropäische Normalzeit) G91 ; relative positioning G1 Z5 F6000 S2 ; lift Z relative to current position G90 ; absolute positioning G1 X122 Y110 F6000 G30 ; probe the bed using z probe to find Z0 G1 Z10 F5000 ; raise z to 10
; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by RepRapFirmware Configuration Tool v2 on Mon Dec 24 2018 14:30:36 GMT+0100 (Mitteleuropäische Normalzeit) M561 ; clear any existing bed transform G28 G30 P0 X15 Y110 Z-99999 ; probe near a leadscrew, half way along Y axis G30 P1 X200 Y110 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
Re: z-homing failed with mini IR March 25, 2019 10:01AM |
; bed.g M561 ; clear any bed transform G30 P0 X35.0 Y137.5 H0 Z-99999 G30 P1 X185.0 Y137.5 H0 Z-99999 S2
Re: z-homing failed with mini IR March 25, 2019 02:02PM |
Re: z-homing failed with mini IR March 25, 2019 05:57PM |
gueee78
I just wonder how two points could or could not be in clockwise order?
I'm kinda clueless at that point.
Re: z-homing failed with mini IR March 25, 2019 06:16PM |
Re: z-homing failed with mini IR March 26, 2019 04:00AM |
Re: z-homing failed with mini IR March 26, 2019 04:26AM |
Re: z-homing failed with mini IR March 26, 2019 05:33AM |
Re: z-homing failed with mini IR March 26, 2019 08:06AM |
; Drives M569 P0 S0 ; Drive 0 goes backwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M569 P4 S1 ; Drive 4 goes forwards M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation M584 X0 Y1 Z2:4 M671 X-27:262 Y117.5:117:5 M92 X80.00 Y80.00 Z400.00 E420.00 ; Set steps per mm M566 X480.00 Y480.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min) M203 X15000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min) M201 X1500.00 Y1500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2) M906 X1500.00 Y1500.00 Z1500.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout
Re: z-homing failed with mini IR March 26, 2019 08:40AM |
Re: z-homing failed with mini IR March 26, 2019 11:35AM |
