Disable heater safety?
May 16, 2019 09:56AM
Hey there, trying to run an Extruder without the heater. Heater and thermistor aren't connected.
When trying to run extruder tool I get a warning :
M120
M83
G1 E10 F900
M121
Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
thoughts?
Cheers!
Re: Disable heater safety?
May 16, 2019 10:00AM
In the M563 tool definition command(s) in config.g, remove the H parameter. Then the tool will not use any heaters.
Alternatively, use M302 to enable cold extrusion.
Edited 1 time(s). Last edit at 05/16/2019 10:00AM by dc42.
May 16, 2019 10:29AM
Cool thanks, it worked.
If already on the subject- why is driver D0 ? it starts the count from 0 as in the E0 ? and not driver number 0 (X ? )
Thanks!
May 16, 2019 03:21PM
Extruders are numbered 0, 1, 2 etc. and it is the extruder number(s) that you specIfy in M563. The mapping from extruders to motor outputs on the Duet can be anything you like, see the M584 command.
May 19, 2019 03:56AM
cool thanks
