Gcode - monitoring what is currently being executed
Posted by jens53
July 04, 2019 11:33PM
Is there a way to have the gcode console show the individual lines of codes that are being executed ? Is there a possibility of single stepping trough the gcode in order to trace a problem ?
Re: Gcode - monitoring what is currently being executed
July 05, 2019 02:19AM
You can see the individual GCode lines if you connect a PC via USB and send M111 S1 P3 to enable GCode debugging.
Single stepping is a facility that I already have under consideration, but is low priority at present - I can see that it would be useful, but you are the first person to request it.
