DeutWiFi & BLTouch connections vs Duet 2 Maestro
Posted by Dunston-UK
September 12, 2019 05:19AM
Hi all
Yes, I do know the connections that are used in the DuetWifi board for the touch, however, on the Duet 2 Maestro board, you connect directly to the header Z probe, has this now been implemented on the DueteWifi as well? if you use an expansion board with the DueteWiFi it uses the expansion header, so where then do you connect a BLTouch too?
Thanks
Re: DeutWiFi & BLTouch connections vs Duet 2 Maestro
September 12, 2019 05:08PM
No, on the Duet WiFi there is no 5V power available on the Z probe connector, and the output pin on that connector is not PWM capable. That's why you have to connect the BLTouch to the expansion connector as well.
September 17, 2019 05:19AM
Thank you dc42, so you have to still piggyback onto the expansion header even when using expansion board correct?
September 17, 2019 08:35AM
Dunston-UK
If you have a DueX2 or DueX5 connected to your Duet, you plug the 3 servo wires from the BLTouch into one of the PWM connectors on the DueX. The black and white wires still go to the Z probe connector.
