Need help with z probe connection or config for duet wifi
Posted by tham40
November 04, 2019 05:37PM
I have a 5v npn normally open Z probe. I click home and the light on the probe comes on when metal is present. but Z keeps on trucking. Not sure what to do next?
Re: Need help with z probe connection or config for duet wifi
November 05, 2019 12:13AM
Did you plug the signal line from the probe into the right port?
IMG_5255_2048x2048.jfif
Custom all metal CoreXY
- Duet 2 Wifi w/ PanelDue 7i
- 330mm x 360mm x 500mm
- 750w Silicon heater
Custom Mendel90
(Backup printer - Old reliable!) - Sold
November 05, 2019 03:50AM
I am connected to the Z probe in on the header that you have circled.
November 05, 2019 11:23AM
Found some answers on another forum. Thanks.
November 05, 2019 11:45AM
Are you sure 5v is enough voltage? Most are listed as 15-32v.
So I have mine set up with the two power wires going directly to the PSU (24v)
and the signal wire heading to the top pin of the connector I circled.
Outside of that, not sure what could be going on. Faulty sensor maybe?
Custom Mendel90
