M3D Quad Crane Using the SD Card on the back of the LCD screen
Posted by kmikesch
November 09, 2019 08:34PM
Hello, does anybody know how to use the sd card slot on the back of the Lcd panel of the M3D Quad Crane using a Duet 2 Maestro Board. I dont want to unplug the microsd card all the time and save the gcode in the special gcode folder. I put some gcodes on a normal sd card and plugged it into the back but i couldn’t access it over the menu. Does somebody know how to do that. Thanks
Re: M3D Quad Crane Using the SD Card on the back of the LCD screen
November 10, 2019 05:42AM
See [duet3d.dozuki.com]. This is the menu file I use to print files from the second SD card:
text R0 C0 F0 T"Select card 1 print file "
button T"Back" A"return"
image R11 C0 L"hline.img"
files R15 N4 I"1:/" A"M32 #0|return|return"
The parameter I"1:/" of the files command tells it to start in the root directory of the second SD card.
Large delta printer [miscsolutions.wordpress.com], Robotdigg SCARA printer, Crane Quad and Ormerod
November 10, 2019 04:06PM
thank you very much, ill answer over at duet3d
