Octopi though paneldue com insteald of USB April 11, 2020 04:06PM |
Connecting to: /dev/ttyAMA0 Changing monitoring state from "Offline" to "Opening serial port" Connected to: Serial(port='/dev/ttyAMA0', baudrate=57600, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor Changing monitoring state from "Opening serial port" to "Connecting" Send: N1 M408*46 Unexpected error while reading serial port, please consult octoprint.log for details: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2823 Please see [faq.octoprint.org] for possible reasons of this. Changing monitoring state from "Connecting" to "Offline (Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2823)" Connection closed, closing down monitor
Re: Octopi though paneldue com insteald of USB April 12, 2020 05:48PM |
Re: Octopi though paneldue com insteald of USB April 13, 2020 01:54PM |
I considered this, but I didn't know where to solder to. I tried to trace it back, but there was no pad left to do a continuity test and I didn't see any traces coming from it (4 layer PCB?) I tried to search for the forum post you mentioned but couldn't find anything and I haven't been able to find a full schematic of the duet 2 PCB. I'll take another look at the board but I don't want to fry it or anything.Quote
dc42
there are other points you can solder them to. Someone reported doing this successfully recently on the Duet3D forum.
Re: Octopi though paneldue com insteald of USB April 13, 2020 06:53PM |
Re: Octopi though paneldue com insteald of USB April 13, 2020 11:35PM |
osterac
osterac
Re: Octopi though paneldue com insteald of USB April 16, 2020 04:22PM |
Re: Octopi though paneldue com insteald of USB April 16, 2020 04:59PM |
Re: Octopi though paneldue com insteald of USB April 19, 2020 10:18PM |
Re: Octopi though paneldue com insteald of USB April 21, 2020 03:39AM |
osterac
I haven't been able to get the USB LED to light up.
osterac
If raw mode is supported in 3.02, does that mean I can use a beta firmware to turn on raw mode?
Re: Octopi though paneldue com insteald of USB April 21, 2020 04:21PM |
M575: Set serial comms parameters ... Snnn Mode: 0 (default in RRF 3 for Duet 3) = disabled; 1 (default for Duet 2) = PanelDue mode, checksum required; 2= raw mode (supported only in RRF 3.0beta13 and later)This is incorrect?
Re: Octopi though paneldue com insteald of USB April 22, 2020 02:58AM |
osterac
https://duet3d.dozuki.com/Wiki/Gcode says this:
Re: Octopi though paneldue com insteald of USB May 06, 2020 01:38PM |
Re: Octopi though paneldue com insteald of USB May 07, 2020 12:14AM |
