Duet 3 resetting during print June 03, 2020 04:55AM |
02/06/2020, 19:42:57 Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin) 02/06/2020, 18:17:07 M32 "0:/gcodes/[PLA ] CFFFP_Top - No Text.gcode" File 0:/gcodes/[PLA ] CFFFP_Top - No Text.gcode selected for printing
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode) Board ID: 08DJM-956L2-G43S4-6J9FA-3S86T-1B5LD Used output buffers: 1 of 40 (10 max) === RTOS === Static ram: 154604 Dynamic ram: 162972 of which 56 recycled Exception stack ram used: 224 Never used ram: 75360 Tasks: NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4944) IDLE(ready,76) Owned mutexes: === Platform === Last reset 00:47:22 ago, cause: watchdog Last software reset at 2020-06-02 18:09, reason: User, spinning module LinuxInterface, available RAM 75056 bytes (slot 2) Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN Error status: 0 MCU temperature: min 35.5, current 35.7, max 40.4 Supply voltage: min 13.0, current 13.0, max 13.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0 Driver 0: standstill, reads 62000, writes 14 timeouts 0, SG min/max 0/0 Driver 1: standstill, reads 62000, writes 14 timeouts 0, SG min/max 0/0 Driver 2: standstill, reads 62001, writes 14 timeouts 0, SG min/max 0/0 Driver 3: standstill, reads 62001, writes 14 timeouts 0, SG min/max 0/0 Driver 4: standstill, reads 62001, writes 14 timeouts 0, SG min/max 0/0 Driver 5: standstill, reads 62005, writes 11 timeouts 0, SG min/max 0/0 Date/time: 2020-06-02 20:30:19 Slowest loop: 4.05ms; fastest: 0.14ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is ready with "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is idle in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 0.68ms; fastest: 0.01ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 0 of 8 - Ethernet - State: disabled Error counts: 0 0 0 0 0 Socket states: 0 0 0 0 0 0 0 0 === CAN === Messages sent 11366, longest wait 0ms for type 0 === Linux interface === State: 0, failed transfers: 0 Last transfer: 19ms ago RX/TX seq numbers: 11820/26640 SPI underruns 0, overruns 0 Number of disconnects: 0 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.1.1 Daemon: Finishing macro daemon.g, started by system > Next stack level Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 32.32
