Dual Z Issues for Ender 3 w/ Duet 2 Wifi April 25, 2021 02:09PM |
board "duetwifi10" firmware 3 nvram false auto_save enabled true save_threshold 10 resume_threshold 11 gcodes_to_run "M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" display type 1 encoder_steps 4 spi_frequency 2000000 menus 0 name "main" value "text C10 R20 \"Powered by Duet3D\"" images [] geometry type "cartesian" mins 0 0 1 0 2 0 maxes 0 235 1 235 2 250 delta_radius 105.6 homed_height 250 low_dive_height false max_carriage_travel 260 print_radius 85 rod_length 215 z_min 0 drives 0 direction 0 microstepping 16 microstepping_interpolation true steps_per_mm 80 instant_dv 20 max_speed 150 acceleration 500 current 800 driver 0 endstop_type 1 endstop_location 1 driver_v3 "0.0" endstop_pin "xstop" 1 direction 0 microstepping 16 microstepping_interpolation true steps_per_mm 80 instant_dv 20 max_speed 150 acceleration 500 current 800 driver 1 endstop_type 1 endstop_location 1 driver_v3 "0.1" endstop_pin "ystop" 2 direction 1 microstepping 16 microstepping_interpolation true steps_per_mm 400 instant_dv 0.4 max_speed 3 acceleration 100 current 800 driver 2 endstop_type 1 endstop_location 1 endstop null driver_v3 "0.2" endstop_pin "zstop" 3 direction 1 microstepping 16 microstepping_interpolation true steps_per_mm 410 instant_dv 5 max_speed 100 acceleration 5000 current 1000 driver 3 driver_v3 "0.3" idle used true factor 50 timeout 30 homing_speed_fast 50 homing_speed_slow 4 travel_speed 100 z_dive_height 5 slow_homing false probe type "noprobe" recovery_time 0.4 trigger_height 2.5 trigger_value 500 x_offset 0 y_offset 0 speed 2 deploy false points [] pwm_channel 64 pwm_inverted false pwm_pin null input_pin "zprobe.in" modulation_pin null bed_is_nozzle false bed present true heater 0 use_pid false chamber present false heater 2 use_pid false heaters 0 temp_limit 150 scale_factor 100 series 4700 thermistor 100000 beta 4092 c 0 channel 0 sensor 0 output_pin "bedheat" sensor_type "thermistor" sensor_pin "bedtemp" 1 temp_limit 290 scale_factor 100 series 4700 thermistor 100000 beta 4092 c 0 channel 1 sensor 1 output_pin "e0heat" sensor_type "thermistor" sensor_pin "e0temp" num_nozzles 1 toolchange_wait_for_temperatures true generate_t_code false tools 0 mix_ratio [] number 0 name "" extruders 0 0 heaters 0 1 fans 0 0 x_offset 0 y_offset 0 z_offset 0 compensation_x_offset 15 compensation_y_offset 15 peripheral_points 3 halfway_points 0 calibration_factors 3 probe_radius 85 mesh x_min 15 x_max 215 y_min 15 y_max 195 radius 85 spacing 20 home_first false orthogonal compensation false height 50 deviations 0 0 1 0 2 0 network enabled true mac_address "" name "" password "" ssid "" ssid_password "" dhcp true ip "" netmask "" gateway "" protocols http true ftp false telnet false fans 0 name "" value 0 inverted false frequency 500 thermostatic false heaters [] trigger_temperature 45 output_pin "fan0" 1 name "" value 100 inverted false frequency 500 thermostatic true heaters 0 1 trigger_temperature 45 output_pin "fan1" 2 name "" value 100 inverted false frequency 500 thermostatic true heaters 0 1 1 0 trigger_temperature 45 output_pin "fan2" custom_settings "" expansion_boards [] standalone true panelDue false
Re: Dual Z Issues for Ender 3 w/ Duet 2 Wifi April 26, 2021 02:43AM |
Re: Dual Z Issues for Ender 3 w/ Duet 2 Wifi April 26, 2021 01:40PM |
