Running a filament at different extrusions rates obviously alters the backpressure so trying to put a 'correct' value in config.g is confusing. One of my 1.75mm PLA filaments would change as a much as 6% between extruding at 1mm/sec and 5 mm/sec (albeit 5 is a little over the thermal volumetric limit for a V6 heater block)
So temperature, extrusion rate, and nozzle-size can all impact the correct encoder steps for a particular print.
Is there a facility or plans for accounting for these? Pressure-advance can only adjust for some established amount of filament-compression (or bowden) so not sure that can be a cure-all, and does not track any of the mentioned variables that impact extrusion rate.
thanks
